Siebel Field Service Integration to Oracle Real-Time Scheduler Implementation Guide > Appointment Booking Integration > Integration Flows That Book an Appointment > Integration Flow That Updates and Inserts an AppointmentThe integration flow to update and insert an appointment is the same as the flow to confirm an appointment described in Integration Flow That Confirms an Appointment except for the following differences:
DVM That Updates and Inserts an AppointmentThe DVM to update and insert an appointment is the same as the DVM to schedule an appointment according to a contract. For more information, see DVM That Schedules an Appointment According to a Contract. Output XSD That Updates and Inserts an AppointmentThe output XML Schema Definition (XSD) to update and insert an appointment is the same as the output XSD it uses to confirm an appointment. For more information, see Integration Services.. |
| Siebel Field Service Integration to Oracle Real-Time Scheduler Implementation Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
