| Siebel CRM System Administration Guide Siebel Innovation Pack 2015, Rev. A E24823-01 |
![]() Previous |
![]() Next |
View PDF |
This topic lists the administration tasks applicable to Siebel Server tasks. It contains the following information:
To start a Siebel Server task, you must run a component job. For information about component jobs and administering component jobs, see the following topics:
This topic is part of "Administering Siebel Server Tasks".
This topic describes how to pause a Siebel Server task. You can pause Siebel Server tasks only for certain component types. Table 7-2 lists the component types and the predefined components that have this feature.
Table 7-2 Pausable Component Types
| Component Types | Predefined Component | Predefined Component Alias |
MailMgr |
Email Manager |
MailMgr |
MktgSrvr |
Marketing Server |
MktgSrvr |
PageMgr |
Page Manager |
PageMgr |
ServerMgr |
Server Manager |
ServerMgr |
TxnMerge |
Transaction Merger |
TxnMerge |
TxnProc |
Transaction Processor |
TxnProc |
TxnRoute |
Transaction Router |
TxnRoute |
WorkActn |
Workflow Action Agent |
WorkActn |
WorkMon |
Workflow Monitor Agent |
WorkMon |
To pause a Siebel Server task
Navigate to Administration - Server Management screen, then the Tasks view.
In the Tasks list, select the Siebel Server task of interest.
Make sure that the Siebel Server task is on the Siebel Server of interest and is of a component type that can be paused. See Table 7-2 for a list of Siebel Server component types that can be paused.
Click Pause.
Related Topics
This topic describes how to resume a paused Siebel Server task.
To resume a paused Siebel Server task
In the Tasks list, select the paused Siebel Server task of interest.
Click Resume.
Related Topics
This topic describes how to stop a Siebel Server task. You can stop running or paused Siebel Server tasks.
Note: It is preferable to stop the individual tasks for a given server component rather than shutting down the server component. |
To stop a Siebel Server task
In the Tasks list, select the running Siebel Server task of interest.
Click Stop.
Related Topics
This topic describes how to terminate a Siebel Server task. Terminating a Siebel Server task signals the Siebel Server to use the operating system control to terminate the task.
To terminate a Siebel Server task
Click Stop three times in succession.
Related Topics
This topic describes how to configure dynamic parameters of a Siebel Server task. Siebel Server task parameters consist of Siebel Enterprise Server, Siebel Server, and server component-level parameters, as well as task-specific parameters specified when starting a component job. After a task is running, only dynamic parameters can be changed.
To configure Siebel Server task dynamic parameters
Click the Parameters tab.
In the Task Parameters list, change the values of the parameters that you want to modify. (Identify dynamic parameters by a check in the Effective Immediately column.)
Select the parameter that you want to modify.
In the Value field, type in the new value.
Click Menu, and then Save Record.
Related Topics
"About Siebel System Parameters"
