| Siebel CRM System Administration Guide Siebel Innovation Pack 2015, Rev. A E24823-01 |
![]() Previous |
![]() Next |
View PDF |
Table C-2 contains an alphabetical listing of some of the configuration parameters from Siebel application configuration files such as siebel.cfg or uagent.cfg. This list shows the name of the section in which each parameter can be found and identifies where the parameter is documented (within Table C-3 and Table C-5). This list is not comprehensive.
Table C-2 Index of Configuration Parameters
| Configuration Parameter Name | Section Name | Where Documented and Description |
AccessDir |
AllowAnonUsers |
Siebel Security Guide |
ApplicationName |
ApplicationPassword |
Applicable security adapter sections, such as:
ApplicationSplashText |
ApplicationTitle |
ApplicationUser |
Applicable security adapter sections |
AutoStopDB |
Applicable data source sections, including:
BaseDN |
CalDAVService |
This parameter and related parameters support a CalDAV integration for the Siebel calendar, using Siebel Enterprise Application Integration (EAI). Add the section Also add the section For more information about configuring a CalDAV integration for the Siebel calendar, see article 1574546.1 (Article ID) on My Oracle Support. |
CancelQueryTimeOut |
Siebel Applications Administration Guide |
CaptionPrefix |
CaseInsensitive |
ClientRootDir |
CommConfigCache |
Siebel CTI Administration Guide |
CommConfigManager |
CommConfigManagerName |
CommEnable |
CommLocalDriver |
CommLogDebug |
CommLogFile |
CommMaxLogKB |
CommMaxMsgQ |
CommReleaseLogHandle |
CommReqTimeout |
ComponentName |
ConnectString |
"ConnectString" (data sources) |
ContactLogin |
Applicable data source sections |
CredentialsAttributeType |
DataSource |
DebugLevel |
DefaultChartFont |
DefaultMailClient |
Siebel Email Administration Guide |
DisableExecuteRetry |
DisableReverseProxy |
DLL |
Docked |
DockConnString |
DockRecvTxnsPerCommit |
DockRepositoryName |
DockTxnsPerCommit |
EditFieldCaption |
Configuring Siebel Business Applications |
EditFieldType |
Enable |
Siebel Data Quality Administration Guide |
EnableCDA |
Siebel Performance Tuning Guide |
EnableEmailClientAutomation |
EnableFQDN |
"Configuring Siebel Business Applications for Pop-Up Blocker Compatibility" |
EnableInlineForList |
If the applet mode property is set to Edit List, then the functions Edit, New, and Query work in-line, that is, in the list applet, when EnableInlineForList is set to True. The default value is True. Set to False to turn off this behavior. |
EnableOpenUI |
Enables Siebel Open UI. Siebel Installation Guide for the operating system you are using Deploying Siebel Open UI Configuring Siebel Open UI |
EnablePersonalization |
EnableResponsive |
Siebel CRM Composer Developer Preview Guide |
EnableScripting |
EnableSIBusyCursor |
EnableWebClientAutomation |
Siebel Email Administration Guide Siebel Object Interfaces Reference Siebel Database Upgrade Guide |
EnterpriseServer |
eProdCfgNumbOfCachedCatalogs |
eProdCfgNumOfCachedObjects |
eProdCfgNumbofCachedWorkers |
eProdCfgSnapshotFlg |
ExtendedKeyboard |
FileSystem |
FQDN |
Chapter 4, "Configuring the Browser for Siebel Web Clients" |
GatewayAddress |
GatewayDataSrc |
Hidden |
HighInteractivity |
Siebel Installation Guide for the operating system you are using |
InsensitivityFactor |
InsUpdAllCols |
IntegratedSecurity |
ListRowStyle |
Local |
LocalDbODBCDataSource |
LoginView |
LotusForm |
MarkupLanguage |
Siebel Wireless Administration Guide |
MaxCachedCursors |
MaxCachedDataSets |
MaxConnections |
MaxCursorSize |
MaxDepthOfTheQuery |
Method |
Specify the value Execute for this parameter. For more information, see the description of the CalDAVService parameter. |
MessageBarUpdateInterval |
MultiCurrency |
NonSQL |
NumberOfListRows |
Siebel Object Types Reference Siebel Wireless Administration Guide Siebel Mobile Connector Guide |
OutlookForm |
PasswordAttributeType |
PersonalizationLog |
Port |
PrefetchSize |
PrimaryEnterprise |
RemoteSearchServer |
RemoteSearchServerPath |
ReportDataDir |
Siebel Reports Guide |
ReportsDir |
ReportOutputDir |
ReportsODBCDataSource |
RepositoryFile |
RequestServerName |
This parameter is the name of the Siebel Server that services requests from the Siebel client. |
RequiredIndicator |
Siebel Developer's Reference |
ReverseFillThreshold |
RolesAttributeType |
Sample |
ScriptingDLL |
SearchDefName |
SearchEngine |
SearchInstallDir |
SecAdptDllName |
SecAdptMode |
SecAdptName |
ServerDataSrc |
ServerName |
Service |
Specify the value CalDAV Service for this parameter. For more information, see the description of the CalDAVService parameter. |
SharedCredentialsDN |
SharedModeUsersDir |
ShowMessageBar |
ShowWriteRecord |
Siebel Partner Relationship Management Administration Guide |
SiebelExtMailClientAttDir |
SiebelUsernameAttributeType |
SingleSignOn |
SortCollation |
SqlStyle |
SslDatabase |
SystemSWFName |
SystemSWSName |
TableOwner |
TempDir |
TreeNodeX (several parameters that are similarly named, for example, TreeNodeCollapseCaption) |
TrustToken |
Type |
UpperCaseLogin |
UseDictionaryinTransaction Logging |
UseAdapterUsername |
UseRemoteConfig |
UserSWFName |
UserSWSName |
Version |
ViewPreloadSize |
View1 |
View2 |
Viewn |
WebTemplatesVersion |
XdoDir |
