| Siebel CRM System Administration Guide Siebel Innovation Pack 2015, Rev. A E24823-01 |
![]() Previous |
![]() Next |
View PDF |
The Siebel Server Manager graphical user interface (GUI) consists of the views in the following server administration screens, which are available from the application Site Map:
Administration - Server Configuration
Administration - Server Management
Server Jobs
Note: The Siebel Server Manager GUI screens allow you to use only the query operator LIKE. |
In general, use the Siebel Server Manager GUI to perform most administrative tasks, because it provides a more intuitive view into the operation of Siebel Servers than does the command-line interface.
The Administration - Server Configuration screen contains a view for reviewing enterprise data in an Explorer or hierarchical format. The Enterprise Explorer view provides an alternate means of navigation and a comprehensive layout of the enterprise data. You access this view by selecting Enterprise Explorer from the link bar.
The Administration - Server Management screen contains the Process Failure Diagnostics view, which you can use for investigating process failures for Siebel Server components. You access this view by selecting Diagnostics from the link bar.
Related Topics
Chapter 8, "Using the Siebel Server Manager Command-Line Interface"
Related Books
Siebel Installation Guide for the operating system you are using
Siebel Applications Administration Guide
Siebel Security Guide
Siebel System Monitoring and Diagnostics Guide
