Table 31. Steps That the upgphys Process Executes
1 Check whether the merge and conflict resolution steps are complete
verify_irm.sql |
Verifies whether the merge and conflict resolution steps are complete. |
If this step stops because of an error, then the conflict resolution has not been completed. For information on resolving the conflict, see Reviewing Siebel Repository Object Property Conflicts. After you resolve the conflict, restart the Siebel Upgrade Wizard, and click No when asked if you want to continue. Then start the Siebel Upgrade Wizard again from the beginning. |
- Drop temporary indexes created for merge performance
drop_temp_indexes_merge.sql |
Removes all the temporary indexes created to improve the merge performance. |
None |
- Export schema definition
None |
Exports the schema definition to the file DBSRVR_ROOT/platform/schema.ddl. This file is used as an input to the production test and production environments. |
None |
- Sync physical and logical tables
schema.ddl |
Applies the schema.ddl and synchronizes the tables. |
None |
- Sync physical and logical indexes
schema.ddl |
Applies the schema.ddl and synchronizes the indexes. |
None |
- Export repository to a file
None |
Exports the New Customer Repository to: $DbsrvrRoot/$DatabasePlatform/custrep.dat
None |
- Import New Customer Repository as Siebel Repository
custrep.dat |
Truncates the repository tables and imports the previously exported New Customer Repository as Siebel Repository. |
None |
- Migrate custom manifest data from XML files to the database
NOTE: This step applies only to upgrades with custom Siebel Open UI manifest files for Siebel CRM version 8.1.1.9 or 8.1.1.10, and version 8.2.2.2 or 8.2.2.3.
- custom_manifest.xml
- manifest_extensions.map
This step migrates Siebel Open UI custom manifest data from XML files to the database. For more information, see About Migrating the XML Manifest Data for Siebel Open UI from Previous Releases to the New Manifest Data in the Database. |
None |
- Migrate query search controls of list applets into the Siebel database
SrchCntrlMigration.jar |
This step migrates query search controls of list applets from files into the Siebel database. |
None |
- Migrate SWT from files into the Siebel database
SWTMigration.jar |
This step migrates Siebel Web template data from files into the Siebel database. For more information, see About Migrating Siebel Web Template Data. |
None |
- Create list import package for Siebel Marketing
mktg_listimp_pkg_spec.sql mktg_listimp_pkg_body.sql |
(Oracle Database only) This step creates a package to support the Siebel Marketing list import functionality for Oracle Database 12c. For more information, see Siebel Marketing Installation and Administration Guide. |
None |
- Verify repository after upgrade
- dbchck
- dictutl
- mlovupgd
- SeedConflict.jar
The repository is optionally verified after you complete the upgphys process. This step is executed if you selected the option Verify Repository After Upgrade in the Database Configuration Wizard. For more information, see Verifying the Repository After Upgrade. |
None |
- Upgrade history
store_history.sql |
Stores the upgrade history in the S_INST_UPG_HIST table. |
None |
