Siebel Database Upgrade Guide > Reviewing the Siebel User Interface >
Reviewing Siebel Grid-Based Applets
Environments: Development environment only. Platforms: Windows, UNIX, IBM z/OS. Reputility log section: "Start Invalid Web Template Item Mapping Clean-up." If a Prior Customer Repository applet that will be converted to grid-based layout has been customized by adding new fields or controls, then the utilities put these fields and controls at the bottom of the applet in the New Customer Repository. After the repository merge, you must reposition these fields and controls. ICL upgrades only: If Incorporate Custom Layouts (ICL) was selected for the repository merge, then ICL converts many form applets to grid-based layout. The postmerge utilities then deactivate the grid-based layout and activate the Prior Customer Repository, flow-based form of the applet. The reputility.log file lists applets that were converted by the postmerge utilities. Review the applets listed in the section of the log referenced above and revise layouts as needed. The log is located here: SIEBEL_TOOLS_ROOT\reppatch\log\reputility.log
Table 38 lists common issues and corrective actions for grid-based applets.
Table 38. Common Grid-Based Applet Issues
STATUS:: Succeed Update AWTI List Mgmt Lists Entry Applet Base Status |
The utility mapped a control to a different location. Action: Review the modified Applet. Verify that the new location for the control works. |
STATUS:: Succeed Delete AWTI List Mgmt Lists Entry Applet Base Status ESN |
To avoid possible overlapping, the utilities deleted a locale record for an applet Web template item. Action: Review the modified Applet Web Template and re-create the locale record. |
WARNING:: Grid -> Grid merge/upgrade, Skip |
Only flow-based form applets are converted to the grid-based Web template. Action: None required. |
WARNING:: Upgrade Ancestor "Account Form Applet" Not Found in New Siebel Repository, Skip |
The utilities did not find the upgrade ancestor's applet Web template in the New Siebel Repository. Action: Review the applet for invalid Web template items. |
WARNING:: Applet Web Template Not Found in New Siebel Repository, Skip |
The utility is trying to find the Applet Web Template from New Siebel Repository, but it is not found. Action: Review the applet for invalid Web template items. |
WARNING:: No List Column Found, Applet "Program Expenditure List Applet", AWT "Edit", AWTI "Type", Control "Type", Skip |
No List Column found for the Applet Web Template Item. Action: Delete the applet Web template item. |
WARNING:: No Control Found, Applet "Expense Item Entry Applet", AWT "Edit", AWTI "Site", Control "Site", Skip |
No Control is found for the Applet Web Template Item. Action: Delete the applet Web Template. |
WARNING:: Button Control, Applet "Expense Item Entry Applet", AWT "Edit", AWTI "NewQuery", Control "NewQuery", Invoke Method "NewQuery", Skip |
If a control has an Invoke Method action defined on it, then the utility treats it as a button and will not remap it. Action: Review the applet and verify that the button control displays correctly. |
Related Topics
Troubleshooting Postmerge Siebel UI Problems
About the Siebel Postmerge Utilities
About the Siebel Repository Merge
Siebel Incorporate Custom Layout Upgrade Option
