Siebel Database Upgrade Guide > Reviewing the Siebel User Interface >
Reviewing Siebel UI Navigation
Environments: Development environment only. Platforms: Windows, UNIX, IBM z/OS. Reputility log section: "User Interface Navigation Upgrade." The postmerge utilities analyze the repository and verify that objects referenced in screens, views and applets are defined correctly. The reputility.log lists objects that need to be modified. Review the section of the log referenced above and make the needed revisions. The log is located here: SIEBEL_TOOLS_ROOT\reppatch\log\reputility.log
Table 39 shows examples of common issues and corrective actions.
Table 39. Common UI Navigation Issues
WARNING:: Project projname is not found in this Repository |
The postmerge utilities exclude certain Siebel Tools projects from UI Navigation cleanup. One of the excluded projects was not found in the repository. Action: None required. |
WARNING:: Ignoring Screen View Record. View Definition Not Found [View: Account Briefing View] |
The utility is unable to read the view definition to determine where it should display. Action: Remove the invalid screen view record that references the invalid view. |
WARNING:: Error Writing Category Record, Ignoring Changes [Name: catname] |
The utility could not update or insert a record in the Siebel database. Possible causes are that the record already exists or there is a database access problem. Action: Verify that a duplicate catname record does not already exist, and then check database access. |
WARNING:: Error Writing Screen View Record, Ignoring Changes [View: viewname] |
The utility could not create a screen view record. Possible cause is that the category does not exist. This error is often a consequence of an error updating or inserting a category record. Action: Verify that the screen view category exists, and then check database access. |
Related Topics
Troubleshooting Postmerge Siebel UI Problems
About the Siebel Postmerge Utilities
About the Siebel Repository Merge
