Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide > Customizing the Integration > Editing the WSDL FilesThe WSDL file that you generated for the inbound Web service in Deploying a Customized Workflow is combined with the original WSDL file provided for the Web service in the Oracle AIA Enterprise Object Library. This revised WSDL file is then used in the Integration. The editing process to combine sections of both WSDL files is described in this topic. This task is a step in Process of Customizing the Integration.
NOTE: The WSDLs for the Siebel CRM Web services used in the Integration are located in Example of an Edited WSDL File for the Loan Account EntityThe following is the WSDL file for the Loan Account entity after it has been edited. You can use this file as a reference when editing the WSDL file required for your customization. <?xml version="1.0" encoding="utf-16"?> ** Oracle Corporation ** Copyright (c) 2007, 2010, Oracle and/or its affiliates. All rights reserved. WSDL File Name <definitions xmlns="http://schemas.xmlsoap.org/wsdl/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/" xmlns:svcdoc="http://xmlns.oracle.com/Services/Documentation/V1" xmlns:corecom="http://xmlns.oracle.com/EnterpriseObjects/Core/Common/V2" xmlns:ebo="http://xmlns.oracle.com/EnterpriseObjects/Core/EBO/LoanAccount/V1" xmlns:ebs="http://xmlns.oracle.com/EnterpriseServices/Core/LoanAccount/V1" name="BankingAndWealthManagementLoanAccountEBSV1" targetNamespace="http://xmlns.oracle.com/EnterpriseServices/Core/LoanAccount/V1"> <xsd:schema targetNamespace="http://xmlns.oracle.com/EnterpriseServices/LoanAccount/V1" elementFormDefault="qualified"> <xsd:import namespace="http://xmlns.oracle.com/EnterpriseObjects/Core/EBO/LoanAccount/V1" schemaLocation="../../../../../../EnterpriseObjectLibrary/Industry/BankingAndWealthManagement/EBO/LoanAccount/V1/LoanAccountEBM.xsd" /> <xsd:import namespace="http://xmlns.oracle.com/EnterpriseObjects/Core/Common/V2" schemaLocation="../../../../../../EnterpriseObjectLibrary/Industry/BankingAndWealthManagement/Common/V2/Meta.xsd" /> <xsd:schema elementFormDefault="qualified" targetNamespace="http://xmlns.oracle.com/EnterpriseObjects/Core/EBO/LoanAccount/V1"> <xsd:element name="UpdateLoanAccount_Input"> <xsd:element ref="ebo:UpdateLoanAccountEBM" /> <xsd:element name="CreateLoanAccount_Input"> <xsd:element ref="ebo:CreateLoanAccountEBM"></xsd:element> <message name="UpdateLoanAccount_Input"> <part name="UpdateLoanAccount_Input" element="ebo:UpdateLoanAccount_Input"></part> <message name="CreateLoanAccount_Input"> <part name="CreateLoanAccount_Input" element="ebo:CreateLoanAccount_Input"></part> <portType name="BankingAndWealthManagementLoanAccountEBS"> <operation name="UpdateLoanAccount"> <input message="ebs:UpdateLoanAccount_Input"></input> <operation name="CreateLoanAccount"> <input message="ebs:CreateLoanAccount_Input"></input> <binding name="BankingAndWealthManagementLoanAccountEBS" type="ebs:BankingAndWealthManagementLoanAccountEBS"> <soap:binding transport="http://schemas.xmlsoap.org/soap/http" style="document" /> <operation name="UpdateLoanAccount"> <soap:operation soapAction="document/http://xmlns.oracle.com/EnterpriseObjects/Core/EBO/LoanAccount/V1:UpdateLoanAccount"></soap:operation> <soap:body use="literal"></soap:body> <!--output> <soap:body use="literal"></soap:body> </output--> <operation name="CreateLoanAccount"> <soap:operation soapAction="document/http://xmlns.oracle.com/EnterpriseObjects/Core/EBO/LoanAccount/V1:CreateLoanAccount"></soap:operation> <soap:body use="literal"></soap:body> <!--output> <soap:body use="literal"></soap:body> </output--> <service name="BankingAndWealthManagementLoanAccountEBSV1"> <port binding="ebs:BankingAndWealthManagementLoanAccountEBS" name="BankingAndWealthManagementLoanAccountEBS"> <soap:address location="http://sdc78514svqe/eai_enu/start.swe?SWEExtSource=SecureWebService&SWEExtCmd=Execute&UserName=SADMIN&Password=MSSQL" /> |
| Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
