Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide > Customizing the Integration > Deploying a Customized WorkflowWorkflows, made available as Web services, perform the real-time synchronization of data in Siebel CRM Integration to Oracle FLEXCUBE Universal Banking. When you extend or customize the Integration, it might be necessary to amend the workflows provided with the Integration or to create new workflows. For information on performing both of these tasks, see Siebel Business Process Framework: Workflow Guide. After you create a new workflow or customize an existing workflow, you must deploy the relevant workflow by publishing it as an inbound Web service and then generating a WSDL file for the new Web service. Both tasks are described in this topic. For detailed information on each of the workflows used in the Integration, see Siebel Finance Guide. The workflow XML files for the Loan Account create and upsert workflows used in the Integration are listed in Sample Workflow Files. You can use these workflow files as a reference when customizing workflows for your integration environment. This task is a step in Process of Customizing the Integration. To deploy a customized workflow
| Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
