Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide > Customizing the Integration > Updating Data Transformation FilesThis topic describes how to update data transformation files when customizing the Integration. This task is a step in Process of Customizing the Integration. The EAI Extensible Stylesheet Language Transformation (XSLT) service is used to transform data from an external integration object structure to a Siebel integration object structure. XSL transformation (XSLT) files for each entity and operation used in the Integration are available in the When customizing the Integration, verify that an XSLT file exists for the entity required for your customization, and that it supports the field data mapping required. If a file does not exist, or if it does not support the field mappings required, you must create a new XSLT file or amend an existing XSLT file for the new entities or fields being synchronized, as described in the following procedure. To update the data transformation files
Example of an XSLT File Created For a New EntityThis topic lists an example of an XSLT file created for an entity that has been imported into Siebel Tools for use in the Integration. It also lists the source and target XML files associated with the new XSLT file. In this example, the CreateLoanAccountResponseEBM entity is imported into Siebel Tools, as described in Step 6; this provides the source XML file. The EAI XSD Wizard then generates the CreateLoanAccountResponseEBM integration object (the target XML file), as described in Step 8. In the XSLT file that must be created for the new entity, the value of the Name field in the source XML file is mapped to the Full Name field in the target XML file. XSL Transformation FileThe following shows the XSLT file created for the new entity to be used in the Integration, CreateLoanAccountResponseEBM. NOTE: The file in this topic is listed for example purposes only; it is not an actual representation of either an AIA EBM or a Siebel CRM XSD file. <?xml version="1.0" encoding="ISO-8859-1"?> <xsl:template match="/"> <xsl:template match="CreateLoanAccountResponseEBM"> <xsl:template match="EBMHeader"> <xsl:template match="Sender"> </xsl:template> XML Source FileThe following shows an example of the CreateLoanAccountResponseEBM XML file imported into Siebel Tools. <?xml version="1.0" encoding="UTF-8" ?> XML Target FileThe following shows an example XML file generated for the CreateLoanAccountResponseEBM integration object in Siebel Tools. <?xml version="1.0" encoding="UTF-8" ?> |
| Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
