Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide > Installing and Configuring the Integration > Process of Configuring Oracle Data Integrator in a Development Environment >
Configuring a Context for the Integration
In an Oracle Data Integrator implementation, a context comprises all the physical resources belonging to a specific environment, for example, the resources in a production or development environment. Contexts are used to link components of the physical architecture (the physical resources) with components of the logical architecture. You must create a context for the Integration as described in this topic. This task is a step in Process of Configuring Oracle Data Integrator in a Development Environment To configure a context for the Integration
- Start ODI Studio, and connect to the ODI work repository you created previously, for example, WORKREP1.
- Open the Topology Navigator, then navigate to Contexts.
- Do one of the following:
- Create a new context for running the ODI interfaces by right-clicking, and selecting New Context.
- Select the existing default value, Release Context, for running ODI Interfaces.
- If you are creating a new context, then enter the context name in the Name field.
- To relate the logical and physical schemas for the Oracle FLEXCUBE and Siebel database servers, do the following:
- Click the Schemas tab.
- In the Logical Schema column, select the Siebel CRM logical schema.
- In the associated Physical Schemas column, select the physical schema to associate with the Siebel CRM logical schema.
- Repeat steps Step b and Step c for the Oracle FLEXCUBE logical schema.
- To verify that the context, for example, Release Context, is correctly assigned to the Siebel CRM and Oracle FLEXCUBE logical schemas, do the following:
- In the Topology Navigator, navigate to Logical Architecture, Technologies, Oracle, and then Oracle FC Server.
- In the Logical Schema editor, verify that the context specified for Oracle FC Server is Release Context.
- In the Topology Navigator, select the Oracle Release Server.
- In the Logical Schema editor, verify that the context specified for Oracle Release Server is Release Context.
