Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide > Installing and Configuring the Integration > Process of Configuring Oracle Data Integrator in a Development Environment > Generating Scenarios for Integration PackagesGenerating a scenario for an object compiles the code required to deploy and execute the object in a production environment. This topic describes how to generate scenarios for the packages provided by the Integration. This task is a step in Process of Configuring Oracle Data Integrator in a Development Environment. The following procedure describes how to generate scenarios for the Integration packages. To generate scenarios for the Integration packages
| Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
