Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide > Installing and Configuring the Integration > Process of Configuring Siebel Business Applications >
Modifying Lists of Values
Siebel CRM comes with many predefined lists of values (LOVs) that support the static lists displayed in the Siebel client. Before implementing the Integration, you must modify a number of LOVs as described in the following procedure. For detailed information on modifying LOVs, see Siebel Applications Administration Guide. This task is a step in Process of Configuring Siebel Business Applications. To modify the LOVs for the Integration
- Log in to the Siebel Financial Services application.
- Navigate to the Administration - Data screen, then the List of Values view.
- Click the menu button, and then choose New Query.
- Enter the Display Value for the record that you want to change in the Display Value field, for example, Citizen.
- Click the menu button, then choose Run Query.
A list of records appears that includes the display value that you entered.
- Select the record that you want to modify, and make the change. For example, for the record with a Display Value of Citizen, deselect the Active field.
- Perform Step 4 to Step 6 for each of the records in the following table.
FIN_CON_CITIZENSHIP |
Citizen |
Deselect the Active field. |
US Citizen |
Permanent Resident |
Resident Alien |
Non-Resident Alien |
Other |
Indian |
Set the Order field to 7. |
British |
Set the Order field to 8. |
American |
Set the Order field to 9. |
NOTE: If you choose to enable citizenship values other than Indian, British, or American, then set the Order field to a value of less than 100.
- To see the modified list-of-values in the Siebel application, click Clear Cache.
