Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide > Installing and Configuring the Integration > Process of Importing the Integration Repository Files in an Oracle Data Integrator Development Environment >
Creating a Work Repository
Before importing the Integration work repository from the Workrep.zip file, you must create a new work repository.
This task is a step in Process of Importing the Integration Repository Files in an Oracle Data Integrator Development Environment and Process of Implementing the Integration in an Oracle Data Integrator Production Environment.
To create a work repository
  1. In ODI Studio, open the Topology navigator.
  2. Navigate to Repositories, then Work Repositories.
  3. Right-click, then select the New Work Repository option.
  4. In the ODI Work Repository connection properties screen, specify the values listed in the following table.
    Parameter
    Value
    Technology
    Select the technology of the server that is to host the work repository, for example, Oracle.
    JDBC Driver
    Specify the driver required to connect to the database where the work repository is defined.
    JDBC URL
    Enter the complete path of the data server hosting the work repository.
    User
    Enter the user ID of the owner of the tables that are to be created for the work repository.
    Password
    Enter the password associated with the table owner user ID.
  5. Click the Test Connection button to verify that the connection is working, then click Next.
  6. On the Specify ODI Work Repository properties screen, specify values for the parameters listed in the following table.
    Parameter
    Value
    Id
    Assign a unique number to the work repository.
    Name
    Enter a name for the work repository, for example, WORKREP1.
    Work Repository Type
    Select Development if you are implementing the Integration in a development environment.
    Select Production if you are implementing the Integration in a production environment.
  7. Click Finish.
    The work repository is created.
  8. Disconnect from the master repository by navigating to the ODI menu option, then selecting the Disconnect "repository_name" option.
Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
