Siebel CRM Integration to Oracle FLEXCUBE Universal Banking Implementation Guide > Installing and Configuring the Integration > Process of Importing the Integration Repository Files in an Oracle Data Integrator Development Environment >
Importing the Work Repository for the Integration
The task of importing the Integration work repository involves creating a new work repository login, connecting to the work repository you previously created, and then importing the Integration work repository. The following procedure describes these tasks. This task is a step in Process of Importing the Integration Repository Files in an Oracle Data Integrator Development Environment. To import the work repository for the Integration
- Start ODI Studio.
- From the ODI menu, choose File, and then the New menu item.
- In the Categories tree, select ODI.
- In the Items list, select Create a New ODI Repository Login.
- In the Repository Connection Information screen, specify the connection information as follows:
- Oracle Data Integrator Connection. Enter the same values for the Connection parameters that you specified when configuring the connection between Oracle Data Integrator and the master repository as described in Installing Oracle Data Integrator.
- Database Connection (Master Repository). Enter the same values for the Database Connection parameters that you specified when configuring the connection between Oracle Data Integrator and the master repository as described in Installing Oracle Data Integrator.
- Work Repository. In the Work repository field, enter the name of the work repository you created in Creating a Work Repository, for example, WORKREP1.
- Click the Test button to test the connection.
- Click the Connect to Repository... link, then select the Work Repository connection.
- Right-click the Designer Navigator, select Import, and then select the Work Repository option.
- In the Import work repository dialog box, select the import mode from the Import Mode list. Select one of the following options:
- Synonym Mode INSERT
- Synonym Mode INSERT UPDATE
- Select the Import from a Zip file option, and enter the path to the workrep.zip file. For information on this file, see Accessing the Integration Files.
NOTE: The import process can take between 30 and 50 minutes to complete. Wait until the import has completed before attempting to perform other operations in Oracle Data Integrator.
When the work repository import is completed the Import Report is displayed.
- Perform the following substeps to explicitly import the work repository projects for the Integration to the work repository. Performing these steps ensures that global variables are mapped to scenarios when the scenarios are generated at a later stage.
- Unzip the workrep.zip file.
- Open the Operator navigator, right-click Scenarios, then select the Import Scenario menu item.
- In the File import directory field, enter the name of the folder containing the unzipped Workrep.zip file.
- Select all the scenarios in the Select the file(s) to import list, then click OK.
