Table 31. Buttons You Can Click on the Edit Toolbar
New |
Starts the New Object Wizard that allows you to create applets, views, charts, and other objects. |
Save |
Saves modifications in the current editing window if you use Layout, Menu, or Basic Scripts. |
Save All |
Saves modifications in all open editing windows. |
Cut |
If you use this button while the cursor is in a property that contains text, then Siebel Tools copies the text you choose to the clipboard and deletes the existing text. In the Applet Designer, it copies the control you choose to the clipboard and deletes the existing control. |
Copy |
If you use this button while the cursor is in a property that contains text, then Siebel Tools copies the text you choose to the clipboard. In the Applet Designer, it copies the control you choose to the clipboard. |
Paste |
Inserts text from the clipboard to a text property at the insertion point. In the Applet Designer, it inserts a control from the clipboard. |
Undo |
If you have not saved the object, then this button reverses the last modification you made to a property value in the Object List Editor or Property window. |
Redo |
Reapplies modifications after the Undo command runs. |
