Table 32. Buttons You Can Click on the List Toolbar
Add New Record |
Creates a new object in the Object List Editor and positions the cursor in the first required property. |
First Record |
Goes to the first object in the list. |
Previous Record |
Goes to the object above the current selection. |
Next Record |
Goes to the object below the current selection. |
Last Record |
Goes to the last object in the list. |
New Query |
Allows you to specify one or more filters on the set of objects that the Object List Editor shows. |
Execute Query |
Runs the query you specify. This button does the same as pressing ENTER. |
Sort Ascending |
Modifies the order that Siebel Tools uses to display objects. It sorts them in ascending order according to the currently chosen property column. |
Sort Descending |
Modifies the order that Siebel Tools uses to display objects. It sorts them in descending order according to the currently chosen property column. |
Filter Version |
Displays only the most recent version of each workflow process or task UI that the Object List Editor shows. |
