Table 34. Buttons You Can Click on the Debug Toolbar
Check Syntax |
Compiles the current script and verifies syntax. |
Start |
Starts the Siebel client. It also displays a dialog box that includes startup parameters. |
Break |
Stops the script that is currently running. If Siebel VB or Siebel eScript is not running, then Siebel Tools does nothing. |
End |
Stops the Siebel client and returns to the Siebel Script Editor window. |
Toggle Breakpoint |
Sets or removes a breakpoint on a line of code. |
Watch |
Displays script variables and their values. For more information, see Using the Watch Window While it Monitors a Script. |
Calls |
Contains a list of subroutine and function calls that Siebel Tools runs prior to the current line. If you choose an item in this list, then the interpreter shifts to this item. |
Step Into |
Runs the next line of a script. If this line calls a subroutine or procedure, then Siebel Tools runs this subroutine or procedure. |
Step Over |
Runs the first line of script that occurs after the current subroutine or procedure. Siebel Tools continues to run this script in the current subroutine or procedure. |
