Using Siebel Tools > Reference Materials for Siebel Tools > Buttons on the Toolbars >
Format Toolbar
Table 36 describes the buttons that you can click on the Format toolbar.
Table 36. Buttons You Can Click on the Format Toolbar
Button
Description
Aligns the left edges of controls.
Aligns the centers of controls along a vertical axis.
Aligns the right edges of controls.
Aligns the tops of controls.
Aligns the middles of controls along a horizontal axis.
Aligns the bottom of controls.
Makes the controls the same width.
Makes the controls the same height.
Makes the controls the same size.
Makes the horizontal spacing between controls equal.
Increases the horizontal spacing between controls.
Decreases the horizontal spacing between controls.
Removes the horizontal spacing between controls.
Makes the vertical spacing between controls equal.
Increases the vertical spacing between controls.
Decreases the vertical spacing between controls.
Removes the vertical spacing between controls.
Centers the controls vertically.
Centers the controls horizontally.
Aligns the labels to the left.
Centers the labels.
Aligns the labels.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
