Using Siebel Tools > Reference Materials for Siebel Tools > Buttons on the Toolbars >
WF/Task Editor Toolbar
Table 37 describes the buttons that you can click on the WF/Task Editor toolbar.
Table 37. Buttons You Can Click on the WF/Task Editor Toolbar
Button
Description
Publish/Activate
Publishes and activates a workflow process or task UI in a single step. This button is available only with the Siebel Web Client. You cannot use it to activate a workflow process or task UI in the production environment.
Publish
Makes a workflow process or task UI available to activate from the Siebel client.
Revise
Revises a workflow process or task UI.
Expire
Makes a workflow process or task UI inactive.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
