Using Siebel Tools > Reference Materials for Siebel Tools > Buttons on the Toolbars >
Configuration Context Toolbar
Table 38 describes the items that you can use on the Configuration Context toolbar.
Table 38. Items You Can Use on the Configuration Context Toolbar
Target Browser |
Allows you to choose a target browser for layout editing and for scripting. |
Application |
Allows you to configure objects for a specific Siebel application. Typically, you use All Applications. If you choose a single application from the list, then you can configure objects, such as applets or views, to show or behave differently for only the application you choose. |
Interactivity |
Allows you to choose High Interactivity or Standard Interactivity. You can configure Web layouts differently, depending on the type of interactivity you choose. |
Variable |
Allows you to specify a display style for an applet for previewing, such as parent, child, or grandchild. Siebel Tools might display an applet differently depending on the underlying Web template. For example, an applet header might not appear if Siebel Tools displays it as a grandchild. |
