Using Siebel Tools > Reference Materials for Siebel Tools >
Buttons in the Palettes Window
Table 39 describes the buttons that the Palettes window shows when you use the Applet Layout Editor. For more information, see Using the Palettes Window.
Table 39. Buttons the Palettes Window Shows with the Applet Layout Editor
Button
Description
CheckBox. Creates an option.
RadioButton. Creates a radio button.
MiniButton. Creates a mini button.
Field. Creates a field.
FieldLabel. Creates a field label.
ComboBox. Creates a combo box.
RecNavNxt. Creates a control for navigating to the next record.
RecNavPrv. Creates a control for navigating to the previous record.
Text. Creates a text box.
TextArea. Creates a text area.
FormSection. Creates a section of a form.
Hidden. Creates hidden HTML.
Password. Creates a text box where the user enters a password during logon.
Link. Creates an HTML link control.
MailTo. Creates a mail-to link.
Button. Creates a button.
Label. Creates a label on templates.
URL. Creates a link to an external URL on a template.
ActiveX. Creates an ActiveX control on a template.
Text List Column. Creates a list column that contains HTML text. Available only for a list applet.
Checkbox List Column. Creates a list column that contains HTML options. Available only for a list applet.
Custom Control. Creates a custom control on a template. To create the custom control, you can choose a custom control from the Control Type drop-down list, and then drag the Custom Control button to the designer.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
