Table 43. Elements of the Validate Dialog Box
Errors List |
Displays the results of the validation process. Each row in the list identifies a rule violation for an object. You can do the following:
- Double click the error in the Errors list to drill down on the object that causes the error.
- Click a column heading to sort the rows.
- Drag the right or left border of the heading cell to resize columns.
Severity Column |
Includes an icon that indicates one of the following:
- Warning. Yellow icon with an exclamation mark.
- Error. Red icon with a minus sign. This error might cause a problem in Siebel CRM at run time.
Rule Column |
Displays an integer that identifies the number of the violated rule. Siebel Tools lists rules sequentially according to the rule number. |
Object Column |
Displays the name of the object that failed validation. |
Description Column |
Displays a description of the error or warning. |
Details Window |
Displays more information about the error or warning message for the row that you choose in the Errors list. |
Go To Button |
To drill down on the object that causes an error, you can choose an error in the Error section, and then click Go To. You can also double-click the error message. |
Log File Window |
Displays the path and file name of the log file that includes the same list of validation errors and warnings that the Errors List shows. To save this list as a log file, you can click Save As, navigate to where you want to save the file, and then specify a file name. |
Load Button |
Loads the contents of the log file that Siebel Tools saves when you use Save As in the Log File section. You can use the Load button to load the list of error and warning validations back into the Validation Tool at a later time. |
Save As Button |
Saves the list of validation rows that Siebel Tools currently shows in the Errors List as a log file. |
