Table 44. Elements of the Rules Area of the Validation Options Dialog Box
Rules List |
Lists the rules that Siebel Tools enforces during validation. You can click a column heading to sort the rows. You can drag the right or left border of the heading cell to resize columns. |
Severity Column |
Displays an icon that indicates one of the following:
- Warning. Yellow icon with an exclamation mark.
- Error. Red icon with a minus sign. This error can cause a problem in Siebel CRM at run time.
Rule Column |
Displays an integer that identifies the number of the violated rule. Siebel Tools lists rules sequentially according to the rule number. |
Object Column |
Displays the object type that Siebel Tools examines. |
Description Column |
Displays a description of the rule. |
Enforce Column |
Indicates if Siebel Tools enforces the rule. A Yes value validates all objects of the object type that the Object column identifies. If you use any of the following buttons in the Validation Options dialog box, then Siebel Tools modifies the value in the Enforce column:
- Enforce
- Ignore
- Enforce All
- Ignore All
Save Button |
Saves all the values for the current set of rules to a text file that you specify. If you press ENTER, and if the Validation Options dialog box is open, then Siebel Tools saves other settings to a preferences file. |
Enforce Button |
Modifies the value in the Enforce column in the row that you choose from No to Yes. |
Ignore Button |
Modifies the value in the Enforce column in the row that you choose from Yes to No. |
Enforce All Button |
Modifies all values in the Enforce column to Yes. |
Ignore All Button |
Modifies all values in the Enforce column to No. If you click Ignore All, then Siebel Tools does not validate any objects. |
Details Text Box |
Displays more information about the error or warning message for the row that you choose in the Errors list. |
Last Validated Option |
If this check box includes a check mark, then Siebel Tools validates only objects that Siebel CRM modified since the date you enter in the Last Validated window. |
Custom Option |
If this check box includes a check mark, then Siebel Tools validates only the objects that Siebel CRM modified according to the date range that you enter in the date and time fields next to the Custom option. |
Do Not Report Warnings Option |
If this check box includes a check mark, then Siebel Tools reports only errors. It does not report warnings. It also modifies the value in the Enforced column of all warning rules to No. |
Abort Validation Option |
If this check box includes a check mark, and if you enter a number in the window that appears to the right of the option, then it stops validating after it reaches the number of errors you specify. If Siebel Tools identifies the number of errors that you specify in this window, then it stops validating the object and displays the Error dialog box. |
