Using Siebel Tools > Reference Materials for Siebel Tools > Menus and Menu Items on the Menu Bar >
File Menu
Table 20 describes the menu items that you can click from the File menu. To use this menu, you click the File menu on the Menu Bar.
Table 20. Menu Items That You Can Click from the File Menu
Menu Item
Description
Open Repository
If multiple repositories reside in the development database, then this menu item allows you to open a repository other than the repository that is currently open. Siebel Tools sets the repository you choose from the Open Repository menu item as the default repository that it opens each time you open Siebel Tools.
New Object
Starts the New Object Wizard that allows you to create a list applet, form applet, chart applet, tree applet, business component, report, table, command, picklist, MVG, or view.
Close
(CTRL+F4)
Closes the Object List Editor.
Save
(CTRL+S)
Saves modifications that the current editing window contains if you edit in one of the following windows: Layout, Menu, or Basic Scripts.
Save All
Saves modifications in all open editing windows.
Import
Imports text from an external text file into the Siebel VB Editor window. This text must use an SBL file format. Siebel Tools creates this format when it exports text from the Siebel VB editor.
Export
Allows you to create a text file in delimited or HTML format that lists the property values of an object or all objects that the Object List Editor currently shows.
Print Setup
Modifies the printer and printing options for printing diagrams from the object visualization view.
Print Preview
Opens a print preview window that displays an object visualization view.
Print
(CTRL+P)
Prints the active object visualization view diagram.
Exit
Closes Siebel Tools.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
