Table 21. Menu Items That You Can Click from the Edit Menu
Undo (CTRL+Z) |
Reverses the last modification you made to a property value in the Object List Editor or the Property window before you save the object. |
Redo (CTRL+Y) |
Reapplies modifications after the Undo command runs. |
Undo Delete |
Siebel Tools displays this menu item if you delete a record in the Object List Editor. It allows you to undo the deletion. |
Undo Record |
If you have not saved the record, then this menu item removes a new object that you create or reverses modifications you made to an existing object. |
New Record (CTRL+N) |
Creates a new object in the Object List Editor and positions the cursor in the first required property. |
Copy Record (CTRL+B) |
Creates a new object that is a copy of the object that you choose. It also creates copies of all child objects. It is recommended that you use the Copy Record menu item only if reusing an existing object is not practical. |
Delete Record (CTRL+D) |
Deletes the object that you choose and the child objects of the object you choose. It is recommended that you do not use the Delete Record menu item. Instead, use the Inactive property. For more information, see Using the Inactive Property. |
Cut (CTRL+X) |
If you use this menu item while your cursor is in a property that contains text, then Siebel Tools copies the text you choose to the clipboard and deletes the existing text. In the Applet Designer, it copies the control you choose to the clipboard and deletes the existing control. |
Copy (CTRL+C) |
If you use this menu item while your cursor is in a property that contains text, then Siebel Tools copies the text you choose to the clipboard. In the Applet Designer, it copies the control you choose to the clipboard. |
Paste (CTRL+V) |
Inserts text from the clipboard into a property at the insertion point. Inserts a control from the clipboard in the Applet Designer. |
Delete (DEL) |
If you use this menu item while your cursor is in a property that contains text, then Siebel Tools deletes the text you choose. In the Applet Designer, it deletes the control you choose. |
Select All (CTRL+A) |
Chooses all items. In the Applet Designer, it chooses all controls that the applet contains. |
Change Records |
Modifies multiple records simultaneously. |
Find (CTRL+F) |
Finds the text that you specify in the Siebel Script Editor window. |
Replace (CTRL+H) |
Replaces the text that you specify with different text in the Siebel Script Editor window. |
