Table 22. Menu Items That You Can Click from the View Menu
Windows |
Palette |
Displays the Palettes window. |
Properties Window |
Displays the Properties window. |
Applets Window |
Displays the Applets window. |
Controls Window |
Displays the Controls/Columns window. |
Bookmarks Window |
Displays the Bookmarks window. |
Web Templates Window |
Displays the Web Templates Explorer window. |
Multi Value Properties Window |
Displays the Multi Value Property Window. |
Refresh Windows |
Requeries and updates the state of dockable windows. |
Reset Windows |
Closes all dockable windows except the Object Explorer for the currently active editor. Does not close editor windows. |
Editors |
Web Applet Editor |
Opens the applet you choose in the Applet Layout Editor, including the Controls/Columns and Palettes windows. |
Server Script Editor |
Opens the Siebel Script Editor. You can specify the editor to use or you can use the default. |
Browser Script Editor |
Opens the Siebel Web Script Editor that you use to access the scripts that control the presentation and behavior of applet controls and list columns in a Web applet template. |
Visualize |
View Details |
For more information, see Viewing Object Relationships. |
View Relationships |
View Descendents |
View Web Hierarchy |
Debug Windows |
Calls (CTRL+L) |
Opens the Calls window. This window displays the call stack of the Siebel VB script or the Siebel eScript script that you are currently debugging. |
Watch (SHIFT+F9) |
Opens the Watch window. This window displays the values of local variables for items you are currently debugging, such as Siebel VB script, Siebel eScript, or Siebel Workflow. |
Errors |
Opens the Errors window. This window displays the run- time errors in the Siebel VB script or Siebel eScript script that you are currently debugging. |
Preview |
Not applicable |
Displays a preview of a Web view layout. This preview approximates how Siebel CRM displays the container page, screen bar, and view bar. |
ActiveX Methods |
Allows you to view the methods for the current ActiveX control in the Applet Designer. |
Toolbars |
Displays the following toolbars: Edit, History, List, Debug, Web Controls, and Configuration Context. |
Status Bar |
Displays the Status bar at the bottom of the Siebel Tools window. |
Object Explorer (CTRL+E) |
Displays the Object Explorer. |
Options |
Opens the Development Tools Options dialog box. For more information, see Development Options for Debugging. |
