Using Siebel Tools > Reference Materials for Siebel Tools > Parameters That Convert Symbolic Strings >
Parameters You Use with the Conversion Export Utility
Table 50 describes the parameters that you can use with the conversion export utility.
Table 50. Parameters You Use with the Conversion Export Utility
Parameter
Description
Filename
Required. Specifies the name of the export file.
Repository
Required. Specifies the name of the repository. The repository name is case sensitive.
Object
Required. Specifies the object type that contains the strings that this utility exports. For example:
Control
The object name is case sensitive.
LogFile
Specifies the name of the log file.
Language
Specifies the language that this utility uses as the primary language to match when it searches for duplicate symbolic strings. For example, each symbolic string includes the following child records:
  • English (ENU)
  • French (FRA)
  • German (DEU)
If you set the Language parameter to ENU, then the conversion export searches for matches between the ENU records. If it finds matches, then it examines the other child records of the other languages. If all child records match, or if one language includes a superset of one of the other languages, then this utility considers them as matching symbolic strings.
MatchMin
Specifies the minimum number of matches in a set of matching symbolic strings before this utility writes them to the file. The default value is 2.
SQLLog
Specifies the SQL log file name. If you set this parameter, then this utility logs all SQL that it runs to this file.
ExcludeNull
Specifies a TRUE or FALSE value. If TRUE, then this utility excludes null values for conversion consideration. The default value is TRUE.
UseFullMatch
Specifies a TRUE or FALSE value. If TRUE, then this utility matches records against all the other possible match candidates before it discards them. The default value is TRUE.
SkipInactive
Specifies a TRUE or FALSE value. If TRUE, and if the Inactive property of the record is set to Y, then this utility skips this record. The default value is TRUE.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
