Table 51. Parameters You Use with the Conversion Import Utility
Filename |
Required. Specifies the name of the import file. You must use the same name that you use when you export symbolic strings. |
Repository |
Required. Specifies the name of the repository. |
LogFile |
Specifies the log file. |
UnlockProjects |
Specifies a TRUE or FALSE value. If TRUE, then this utility unlocks all projects when the conversion finishes. This configuration is useful if multiple instances of the conversion service run against the same database. The default value is TRUE. |
SkipParentUpdates |
Specifies a TRUE or FALSE value. If TRUE, then this utility does not update parent objects to use the symbolic string. The default value is FALSE. Set SkipParentUpdates to TRUE only if you do not simultaneously run multiple instances of the import. If you set SkipParentUpdates to TRUE, and if you run multiple instances, then errors might occur. The utility might abort an update or delete records because another instance updates the project at the same time. |
SQLLog |
Specifies the log file name. If you use this parameter, then this utility logs all SQL that it runs to the file you specify. |
Project |
Required. Specifies the name of the project in the repository that includes the new strings. Predefined symbolic strings reside in the Symbolic Strings project. You can configure this utility to import custom strings. For more information, see About Predefined Objects. |
DeleteLocales |
Specifies a TRUE or FALSE value. If TRUE, and if all translatable strings are NULL, and if language override is not enabled, then this utility deletes locale records. If FALSE, then this utility sets the locale record to Inactive. The default value is TRUE. For more information, see Enabling Language Override. |
CheckTranslateFlag |
Specifies a TRUE or FALSE value. If TRUE, and if the Translate property for the object is N, then this utility does not convert this object. The default value is TRUE. |
LogErrorRecords |
Specifies a TRUE or FALSE value. If TRUE, then this utility exports all error records to a separate log file. The default value is FALSE. |
