Table 24. Menu Items That You Can Click from the Go Menu
Back |
Displays the previous screen in a sequence. |
Forward |
Displays the next screen in a sequence. |
Previous Record (CTRL+UP) |
Navigates to the first object that is above the current selection. |
Next Record (CTRL+DOWN) |
Navigates to the first object that is below the current selection. |
First Record (CTRL+PAGE UP) |
Navigates to the first object in the list. |
Last Record (CTRL+PAGE DOWN) |
Navigates to the last object in the list. |
Add Bookmark |
Displays the Add Bookmark dialog box that allows you to create a bookmark to the object you choose. You can use this menu item to create a bookmark, which is a feature that allows you to return directly to an item. |
Bookmark List |
Displays the Bookmarks dialog box that allows you to choose an existing bookmark. You can also use this dialog box to rename or delete an existing bookmark. |
