Using Siebel Tools > Reference Materials for Siebel Tools > Menus and Menu Items on the Menu Bar >
Query Menu
Table 25 describes the menu items that you can click from the Query menu. This menu allows you to create and refine an Object List Editor query. You can use this query to filter the list of objects that appear in the current Object List Editor.
Table 25. Menu Items That You Can Click from the Query Menu
New Query (CTRL+Q) |
Allows you to filter the set of objects that appear in the Object List Editor. |
Refine Query (CTRL+R) |
Allows you to add more filters to the current query. |
Execute Query (ENTER) |
Runs the query. |
Sort Order |
Opens the Sort Order dialog box. This dialog box allows you to specify the order that the Object List Editor uses to display the records. |
