Using Siebel Tools > Reference Materials for Siebel Tools > Menus and Menu Items on the Menu Bar >
Format Menu
Table 26 describes the menu items that you can click from the Format menu. This menu in the Applet Layout Editor allows you to position controls, configure the grid, and adjust tab or list column order.
Table 26. Menu Items That You Can Click from the Format Menu
Menu Item
Description
Align
Aligns the items you choose.
Make Same Size
Makes all items you choose the same size.
Horizontal Spacing
Adjusts horizontal spacing between items.
Vertical Spacing
Adjusts vertical spacing between items.
Center in Applet
Centers the items you choose horizontally or vertically.
Set Label Alignment
Aligns labels in applets for Web templates that use a grid layout.
Set Tab Order
Sets the tab order for fields in a form applet. This item is not available for list applets.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
