Table 27. Menu Items That You Can Click from the Debug Menu
Check Syntax |
Compiles the current script and verifies syntax. |
Start (F5) |
Starts the Siebel client. It also displays a dialog box that includes startup parameters. |
Break (CTRL+BREAK) |
Stops the script that is currently running. If Siebel VB or Siebel eScript is not running, then Siebel Tools does nothing. |
End |
Stops the Siebel client and returns to the Siebel Script Editor window. |
Restart (SHIFT+F5) |
Restarts the Siebel client if a break occurs. |
Toggle Breakpoint (F9) |
Sets or removes a breakpoint on a line of code. |
Clear All Breakpoints (CTRL+SHIFT+F9) |
Removes all breakpoints from the current script. |
Watch (SHIFT+F9) |
Displays script variables and their values. For more information, see Using the Watch Window While it Monitors a Script. |
Calls (CTRL+L) |
Contains a list of subroutine and function calls that Siebel Tools runs prior to the current line. If you choose an item in this list, then the interpreter shifts to this item. |
Step Into (F8) |
Runs the next line of a script. If this line calls a subroutine or procedure, then Siebel Tools runs this subroutine or procedure. |
Step Over (SHIFT+F8) |
Runs the first line of script that occurs after the current subroutine or procedure. Siebel Tools continues to run this script in the current subroutine or procedure. |
Step To Cursor (CTRL+F8) |
Runs all lines of code up to the line that includes the cursor. |
