Using Siebel Tools > Checking Out and Checking In Projects and Objects > Customizing Projects > Modifying the Project That an Object ReferencesYou can modify the project that an object references. This configuration might be useful if you want to separate a large project into smaller projects. To modify the project that an object references
Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
