Using Siebel Tools > Checking Out and Checking In Projects and Objects > Customizing Projects > Modifying the Location Where Siebel Tools Saves Objects and ProjectsSiebel Tools temporarily stores an object or project that you check out or check in as an archive file in the following location:
You can modify this |
Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
