Siebel VB Language Reference > Methods Reference for Siebel VB > Array Methods > Erase Array MethodThe Erase Array method erases the contents of a fixed array or frees the storage associated with a dynamic array. It does not return a value. The following table describes how it erases the contents of different element types.
FormatThe following table describes the arguments that you can use with this method. ExampleThe following example prompts the user for a list of item numbers to put into an array. If the user must start over, then it clears the array. For information about the Dim statement, see Declare Variable Statement: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
