| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel VB Language Reference > Methods Reference for Siebel VB > Variable Manipulation Methods > Declare Variable StatementThe Declare Variable statement declares a variable. It does not return a value. For more information about the format and arguments you can use this statement, see Declaring Variables. Dim is an abbreviation for Declare in Memory. You must begin the value in the VariableName argument with a letter. It must contain only letters, numbers, and underscores. You can use square brackets to separate a name. You can use any character between the square brackets except for more square brackets. For example:
 FormatDim [Shared] variableName [As[ New] type] [, variableName [As[ New] type]] ... The following table describes the arguments that you can use with this method. ExampleThe following example includes a Dim statement for each of the possible data types: ' Must define a record type before you can declare a record  Sub Button_Click Related TopicsCreate Function Method  |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
