| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel VB Language Reference > Methods Reference for Siebel VB > Array Methods > Set Array Lower Boundary MethodThe Set Array Lower Boundary method specifies the default lower boundary to use for an array. It does not return a value. Note the following:
 FormatThe following table describes the arguments that you can use with this method. ExampleFor an example, see Get Array Lower Boundary Method.  |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
