Siebel VB Language Reference > Methods Reference for Siebel VB > Array Methods > Get Array Upper Boundary MethodThe Get Array Upper Boundary method returns the upper boundary an array. You can use the Get Array Lower Boundary method with the Get Array Upper Boundary method to determine the length of an array. The minimum value for the lower boundary of an array is 0. The maximum value for the upper boundary of an array is 65,536. FormatThe following table describes the arguments that you can use with this method.
ExampleFor an example, see Get Array Lower Boundary Method. |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
