| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel VB Language Reference > Methods Reference for Siebel VB > Mathematical Methods > Get Absolute Value MethodThe Get Absolute Value method returns the absolute value of the value that the number argument contains. The data type of the return value matches the data type of the value in the number argument. This method does the following:
 For more information, see Variants. FormatThe following table describes the arguments that you can use with this method. ExampleThe following example determines the difference between the oldacct variable and the newacct variable: Sub Button_Click  |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
