Siebel VB Language Reference > Methods Reference for Siebel VB > Mathematical Methods > Get ANSI Integer MethodThe Get ANSI Integer method returns an integer that corresponds to the ANSI code of the first character in the string that you specify. You can use the Get ANSI String method to modify an ANSI code to string characters. For more information, see Get ANSI String Method. FormatThe following table describes the arguments that you can use with this method. ExampleThe following example asks the user for a letter and returns the ANSI value for this letter: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
