Siebel VB Language Reference > Methods Reference for Siebel VB > Mathematical Methods > Get Arctangent MethodThe Get Arctangent method returns the angle in radians of the arctangent of a number that you specify. It assumes the value in the number argument is the ratio of two sides of a right triangle: the side opposite the angle to find and the side adjacent to the angle. It returns a single-precision value for a ratio expressed as an integer, a currency, or a single-precision numeric expression. The return value is a double-precision value for any of the following numeric expressions: You can multiply a value by (180/PI) to convert radians to degrees. The value of PI is approximately 3.14159. FormatThis method uses the same arguments as the Get Absolute Value method. For more information, see Get Absolute Value Method. ExampleThe following example finds the roof angle necessary for a house that includes an attic ceiling height of 8 feet at the roof peak and a 16 foot span from the outside wall to the center of the house. The Get Arctangent method returns the angle in radians. It multiplies this value by 180/PI to convert it to degrees: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
