Siebel VB Language Reference > Methods Reference for Siebel VB > Mathematical Methods > Get Cosine MethodThe Get Cosine method returns the cosine of an angle. The angle can be positive or negative. The return value is between negative 1 and 1. To convert degrees to radians, this method multiples the return value by (PI/180). The value of PI is approximately 3.14159. FormatThe following table describes the arguments that you can use with this method. ExampleThe following example finds the length of a roof, given the roof pitch, and the distance of the house from the house center to the outside wall of the house: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
