Siebel VB Language Reference > Methods Reference for Siebel VB > Mathematical Methods > Get Number Sign MethodThe Get Number Sign method returns a value that identifies the sign of a number. It returns a different value depending on the following value of the number:
FormatThis method uses the same arguments as the Get Absolute Value method. For more information, see Get Absolute Value Method. ExampleThe following example examines the value of the profit variable. If this value is a negative number, then it displays 0 for profit: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
