Siebel VB Language Reference > Methods Reference for Siebel VB > Mathematical Methods > Get Sine MethodThe Get Sine method returns the sine of an angle specified in radians. The return value is between -1 and 1. You specify the angle in radians as a positive or negative number. To convert degrees to radians, this method multiplies degrees by (PI/180). The value of PI is 3.14159. For information on how this method handles the data type, see How Some Math Methods Handle the Data Type. FormatThe following table describes the arguments that you can use with this method. ExampleThe following example finds the height of a building, given the length of the roof and the roof pitch: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
