Siebel VB Language Reference > Methods Reference for Siebel VB > Mathematical Methods > Get Square Root MethodThe Get Square Root method returns the square root of a number. For information on how this method handles the data type, see How Some Math Methods Handle the Data Type. FormatThe following table describes the arguments that you can use with this method. ExampleFor an example that calculates the square root of 2 as a double-precision floating-point value and displays it in scientific notation, see Set String Format Method. |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
