Siebel VB Language Reference > Methods Reference for Siebel VB > Mathematical Methods > Get Tangent MethodThe Get Tangent method returns the tangent of an angle in radians. You specify the value in the number argument in radians. This value can be positive or negative. To convert degrees to radians, this method multiplies degrees by PI/180. The value of PI is 3.14159. For information on how this method handles the data type, see How Some Math Methods Handle the Data Type. FormatThe following table describes the arguments that you can use with this method.
ExampleThe following example finds the height of the exterior wall of a building, given the roof pitch and the length of the building: Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
