| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Siebel VB Language Reference > Methods Reference for Siebel VB > Date and Time Methods > Extract Minute From Date-Time Value MethodThe Extract Minute From Date-Time Value method returns the minute component of a date and time value. The return value is an integer variable type in the range of 0 through 59. If the return value is null, then this method returns a null variable type. For more information, see Variants. FormatThe argument that this method uses is the same as the argument that the Convert String to Time method uses. For more information, see Convert String to Time Method. If the value that the time argument contains does not evaluate to a date and time or to a time value, then this method returns 0 (zero). For example: ExampleThe following example gets the hour, minute, and second of the last modification date and time of a file: Sub Button_Click  |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
