Siebel VB Language Reference > Methods Reference for Siebel VB > ODBC Methods > ODBC Get Errors MethodThe ODBC Get Errors method is a Siebel VB method that gets detailed information about errors that occur during an ODBC method call. It returns errors for the last ODBC method and the last connection. FormatThe following table describes the arguments that you can use with this method. UsageThe ODBC Get Errors method returns detailed information for each detected error to the caller in the destination array. It fills each row of the destination array with information for one error. The following table describes how it fills elements of each row with data. If no errors from a previous ODBC method call are present, then it returns a 0 (zero) in the array at the first element of the first row. If the array is not two dimensional or if it does not provide for the return of the preceding three elements, then it returns an error message in the array at the first element of the first row. ExampleThe following example forces an error as a way to test the ODBC Get Errors method: Sub Button_Click ' Open the data source ' force an error to test SQLError choose a nonexistent table ' Retrieve the detailed error message information into the |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
