Siebel VB Language Reference > Methods Reference for Siebel VB > ODBC Methods > ODBC Close Connection MethodThe ODBC Close Connection method is a Siebel VB method that disconnects from an ODBC data source connection that the ODBC Open method established. It returns a variant that includes one of the following values: If you call the ODBC Close Connection method with an argument that is not valid, then it replies with the undocumented return code of -2 (negative two), which indicates a data source connection that is not valid. The following items are examples of arguments that are not valid: FormatThe following table describes the arguments that you can use with this method.
ExampleThe following example opens the data source named Sub Button_Click |
| Siebel VB Language Reference | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
